These are not cheap but they have new seals and pistons.
https://www.ebay.co.uk/itm/Toyota-MR2-R ... Sw3FBbFSSn
You could contact them about any specific requirements you have ie colour if black coating not to your taste.
They may even offer a rebate after you send them yours.
Alternatively if you are not coating them, and the pistons aren't rusted solid you could refurb yourself in a day using the biggred kit.
You would need the toyota tool
(that you can buy from a dealer for about
£4) to hold down the self adjuster mech while you remove the circlip.
You will also need a pair of long nose pliers with fine tip to remove the circlip
(unless you own some long nose circlip pliers!!).
This is the trickiest bit of the whole refurb.
The rest is just disassemble clean, grease and reassemble.
