Variable Geometry Turbo as a kit?
Just wondering if anyone had made a Variable Geometry turbo kit for the MR2?
Re: Variable Geometry Turbo as a kit?
Not in kit form that I've seen.
TBH though if you're looking at this kind of thing then custom exhaust
/ manifold adapter
/ custom manifold shouldn't be an issue.
I assume you have an ECU that can control it?
Hi Gazza, Thanks for getting back to me.
While personally I've gone off turbos since i've started playing with larger displacement engines, but was curious was such a kit available as it would be a tempting route to go rev turbo
& VGTurbo.
Had a look around and as far as I can see the variable geometry turbos by garret all seem more oriented towards diesels, the biggest I could find was a gt2571v which if I've done the maths right would produce a barrel load of torque by start strangling a 2 litre petrol at about 5500-6000rpm
Were I to go down that route, if I couldnt find a pressure rather than vacuum/electronic actuated VGT turbo to base the build around, having previously taught myself picbasic I'd just knock up a small microcontroller for controlling the boost.
I've got access to a milling machine so could make an exhaust manifold adapter and being a hydraulics tech to trade, I could take care of the oil pipes, but for all that work, I'd rather put in a 2gr-fe.
Porsche use variable vein turbos, if that was a route you were after then research what they use and see if there are similar items available.
Borg warner springs to mind.
