And now shes dead.
So, Im in a bit of a predicament where my dream car and temporary daily driver is completely out of action, Ive attempted a bunch of stuff as below to no joy, and so I turn to you wonderful people.
Im going to video what happens tomorrow when I have some more light and can upload this here.
Driving along to work, cruising in 5th at
Get her towed home by a friend and do some investigation, valve cover gasket is leaking oil and its dropped low, check in spark plug holes and theres a little oil in them, check the plugs themselves and theres oil beaded up on their tips.
Engine fires nearly instantly, and runs perfectly smoothly for around 30 seconds, it then starts to shudder as if misfiring occasionally.
If I try to start it straight away after, itll only run for 2-3 seconds then die, or not start at all, however If I leave it for an Hour or so it resets to stage one and goes for 30ish secs.
Touching the throttle only makes it die faster.
I have noticed that the ignition lead in cylinder 3 doesnt quite
Maybe a timing issue? I Have a receipt for the belt 20k miles ago though, so I doubt thats the culprit.
Any thoughts or advice would be kindly appreciated.
