Platmatt`s SMG project
Re: Platmatt`s SMG project
Although the wheels are perfect size and stagger for the MR2 I'd like to fit new longer studs and 10mm spacers.
LED number plate lamp update
Need to get this bolster sorted
But also looking into fitted seat covers
Well, I've fitted extended studs and 10mm spacers to improve the stance and fill the arches better.
Next job is to replace these capacitors on the speedo.
I've bought 2 sets of the 3 incase I bu88er them up.
For info they came from maplins
KQ63 6.8uf 50v
KQ70 100uf 25v
KQ65 2.2uf 35v
KQ63 6.8uf 50v
KQ70 100uf 25v
KQ65 2.2uf 35v
Look what rolled out of my garage today after Santa brought me a new battery xmas prezzy.
Oooooooo can you fix your old links? Car looks great
Wow, not seen this beast in a while!
Yeah Ill try and fix pictures but its not gonna be easy.
Car is filthy as you can see the layers of dust on the bonnet.
Im gonna give it a wash tomorrow and then give it a dam good wax n polish.
The Dep 2 Pro is also coming off Im favour of the stock exhaust, I think Im getting a bit old for loud exhausts
Looks great mate.
I'm not a fan of the number plate surround personally, but it does look great.
Well done!
J-1 wrote:Looks great mate.I'm not a fan of the number plate surround personally, but it does look great.
Well done!
Youre not a fan of the surround! How dare you!!
It actually wasnt my cup of tea at first, but when I bought the car it had allround band holding the plate on and when I went to Halfords chrome is the only one they had.
But when the crystal indicators were fitted it all made sense.
Ok well not much to update but.
Freshly painted OEM turbo exhaust is back on in place of the Dep 2
Rear Quarter have been changed for Import version
(put wrong ones in 4 years ago
Put up some garage wall art.
looking good dude, how difficult was the glass change?
Pretty easy after you have done it a couple of times.
Internal trim out, 3 nuts holding glass on the inside 3 screws on the outside.
Toughest part is the black seals bonding it to the body work.
platmatt8 wrote:Pretty easy after you have done it a couple of times.
Internal trim out, 3 nuts holding glass on the inside 3 screws on the outside.![]()
what did you use? when i took my rear window out i used a sharp kitchen knife, then a stanley to clean left overs up.
rossonza wrote:platmatt8 wrote:Pretty easy after you have done it a couple of times.
Cheese wire, pre paint wipes, blunt chisel.
platmatt8 wrote:rossonza wrote:platmatt8 wrote:Pretty easy after you have done it a couple of times.
MOT Tomorrow
Bit nervous though 1st MOT in 4 years
Can anyone guess the text in red n white?
