STOPTECH SUPRA TURBO SLOTTED HANDED FRONT DISKS 324mm NEW + DELTA AV MOUNTING BRACKETS. USES STD CALIPERS REV345 TURBO .INC FULL FITTING KIT NEW £395 or make me an offer
it uses the stock front caliper so fitment shouldn't be an issue though obv you'll need 17inch front wheels to clear. If you chech what clearance you have the now then that'll give you the best idea
