By ripped out do you mean you have pulled the sounder and/office from box out by either unplugging or cutting the wires? If that's the case you will leave the car disabled.
Get u red the dash driver's side with all the trim out of the way.
Follow all the ignition wires back from the barrel and at some point you will find one of the ignition wires
(at least one, maybe 2) cut and probably black wires attached to each cut end.
Remove the attached alarm wires and rejoin the mr2 wire back together.
You may need to do this on the fuel feed also.
Some immobilizers work on just one circuit, some can work on 3!
