I've gone with him.
As you can see the pistons and head have a fair amount of damage to them.
He said this is all caused due to DET and most likely from the map, the only
Other thing that could cause it is any drastic changes since the map, which
Hasn't happened
One other thing is the damaged ringlands
Blessing in disguise as it's showed my engine was DETing once it's been
Stripped and investigated, otherwise I would have kept on driving until
It really went bang
So we just had a large discussion over the phone to decide the shopping list,
He's again asked me my plans for power.
And therefore it has given Simon the idea that there are things I don't need.
One good thing is that the bores seem to be really good and therefore don't
Need any work, so we will use 86mm Forged CP Pistons.
A new clutch, so we will go updated and most probably a Helix clutch
As that's what Simon prefers.
From the DET damage, and even said if I wanted I could leave the bearings
That the engine has in there as they are in good condition.
Change which I also agree with.
Days, so a Mishimoto rad will be bought and we can remove the AC system
At the same time.
The list should be something like the below.
CP 86mm Forged Pistons
Toyota water pump
Toyota gasket kit
ARP head stud conversion
Toyota oil pump
Helix clutch
ACL race bearings
Mishimoto Rad
I'm sure there are parts I have forgotten
