Which map sensor REV2
which MAP sensor i should use with Link ECU.
is it ok stock sensor
Re: Which map sensor REV2
any one
How much boost do you want to give it?
JD wrote:How much boost do you want to give it?
1.2Bar
Tomas_St wrote:JD wrote:How much boost do you want to give it?
1.2Bar
Standard Rev3+ MAP sensor is fine.
