Need help with upgrading to rev 3 lights!!
caldridge7
Post by caldridge7 »
So I'm upgrading From rev 2 lights to rev 3 wonderig what I need, do I need new brackets etc wiring? Things like that.
Re: Need help with upgrading to rev 3 lights!!
Post by Martin F »
You will also require the centre panel, two brackets that hold that in place, the screws and the key lock. Pretty sure the wiring is the same however it is a very small loom and i see no reason why the seller wouldn't just send it with the lights if required, could come in handy if you are going for the twin lifghts look :-k
monkeyra
Premium Member
Post by monkeyra »
Brackets to hold the centre panel and a rev 3+ bootlock as it's longer.
SW20 Rev1 Supercharged 2GR-FE Powered Trackday Car.
CalMac
Post by CalMac »
Also if it's a Rev 1 (maybe a 2 also) you'll need a hammer, the lights won't sit far enough into the bodywork otherwise :thumleft:
caldridge7
What if I buy a flush centre panel without the reverse lights what happens to the boot lock?
pbmr2
Post by pbmr2 »
nothing stopping you covering the lock, if you never want to use it again.
TBH in 5 years of '2 ownership, never used the boot lock once.
aussieGT
Post by aussieGT »
pbmr2 wrote:nothing stopping you covering the lock, if you never want to use it again.
Always very handy to have if/when the boot release cable snaps.
