Firstly looked on all Mr2 forums can't find the answer I need,
I'm looking at buying new 17" wheels I've got
8j et35 all round at moment f 215/40 r 245/40
Question is will 9j et35 with 245/40/17 go on the rear?
Cars lowered about 40mm on koni inserts
Would I need arches rolling or would they go on with no
Rubbing/catching?
9j eat rear wheels
9j eat rear wheels
Too weird to live, to rare to die
Re: 9j eat rear wheels
This is mine when I bought it, the rear wheels were 18"x9" +35 With 255/35R18 tyres, the arches were rolled, no rubbing but clearance was tight.
Thanks looks mint but need wanting to know
If anyone has run 17x9 et35 245/40/17
On 40 mm drop without any mods or problems
I'm running 17" 275's on 9jj dropped on coilovers, I don't have any issues.
SW20 Rev1 Supercharged 2GR-FE Powered Trackday Car.
I think you might have some rubbing.
I'm running 8J et 33 rears with a 25mm spacer - 225/45/16 and they do scrub occasionally on bumpy corners etc. You could probably get away with just using some camber bolts to bring the top of the wheel in though
EDIT my wheels are sticking out about 1/2" further than you describe. Brainfart, sorry
Thanks for the replys I'm readind very conflicting results on
All different forums,
Was hoping someone hag that exact setup
i have 9inch rears, ET35 17's. I first put on 245x40 and they rubbed so got arches rolled. Now running 255x40 and still no rubbing. Stock suspension but sagging OEM springs lol
Lol looks like arches are getting rolled then
benjo wrote:What you got on front? And any problems?
me? 8x17 ET35 but I wish I had something more like 7.5x17 ET25-30. 8inch front rim is wasted on our cars, stock body
it'll still work and with some suspension massaging you can fit 235x40x17 on there for good measure though I have to say 215x40 AD08 are pretty damned square on the 8inch rims I'm using
Just an update fitted wheels and had no catching issues at all
