Porterfield Brake Pads
JLW
Re: Porterfield Brake Pads
Post by JLW »
TCB has also recommended the RBF660 ,
guess I'll give that a try , is 500ml all that's needed
For a full flush and re-fill ?
JLW
Post by JLW »
So Ive had some interesting info from Porterfield directly that their
R4S is actually a pre-bed pad. So supposedly no bedding in is necessary.
Im due to get the car back soon and wondering if its worth doing a procedure anyway ?
The discs are brand new obviously, so will it be any different ?
SonicSW20
Post by SonicSW20 »
Still need to transfer pad material to the disc though don't you?
http://www.ricambiamerica.com/guides/po ... tructions/
JLW
Post by JLW »
Gazza_DJ wrote:Still need to transfer pad material to the disc though don't you?
exactly what I was thinking, tbh I wasnt sure but thought that
there had to be some kind of process needed. Porterfield were
very vauge and Garage Whiffbitz even more so !!
Ill stick to the bed in procedure !
