Battery is not charging, but it ls not draining power either, seems when the car is running there is enough power from the alternator to power everything but not charge the battery.
I have checked the eng-ig, Alt Sensing, AM2 fuses
Also my reverse lights are not working, and i read that it could be related, but i cant see how, also i have read about swapping rhe fan relays, there are 3 and they are different shapes?!?!
I am going to check the 3 pin plug on the alternator tomorrow.
Anything else i should look for?
