Paul
Jamez87 wrote:This is where I'm at now..
Found the cause of the sticky throttle and why it was possibly idling high before.The throttle stop/butt had come loose, so throttle wasn't returning to where it should be, possible loose throttle cable too I guess.
Anyway got that sorted.
At the moment, from cold, I turn the car on and the revs raise above 1k like they should and then drop down to roughly 900.At this point with the gauge still cold the idle jumps between 900 and 500 and the car smells really rich.
As soon as the gauge hits half way, the revs stabilize around 900, though it is still hunting and not steady but its not trying to cut out and it sounds better etc.
So its better then it has been.I'm now wandering if there is a link to the temp, instead of the throttle body?
(Don't worry I'll still get this cleaned, hopefully at the weekend!)
Jamez87 wrote:I was sort of on the understanding that leaving it running for 10 or so minutes was enough?
