Rev 3 turbo boost spike
Re: Rev 3 turbo boost spike
Does everyone agree with
androo007 about not goin over 14 psi with standard intercooler
It's just an opinion but it's up to you.
So many cars just have boost whacked up no proper supporting mods boosted to the limits of safety then complain when the engine gives after 6 months of batting the fzck out of it.
A upgraded intercooler is what i was intending to do next anyway, i was just aiming for 15 psi because this is what it was boosting at when i brought the car last year.
Then the car dropped boost to about 12 to 13 psi and it sounded like a leak that was pulsating, so after a bit if digging on the net i brought a cheapo ebay mbc so i could set back at 15 psi and block off t-vsv.
This is why i assumed 15 psi might of been ok and why i was asking for a general feeling on the subject.
Thanks for reply
Thanks for reply
high and low boost are just 2 different boost settings that you can set yourself, one for low boost when crawling around town and then switch to the high boost setting when you want full power, the gain setting is were you adjust the boost up or down
stock boost on a rev3 is 12/13psi
C35Rob wrote:yeah I'd read that before, seems interesting, have you played about with it/got it installed yet?
probably minimal difference in hassle too, since you won't have to pull half of the interior out to run cables etc
All i've done so far is power it up out of the car and connect to it to test it works, I had been waiting on the usb/serial adapter as Greddy fitted a USB port on the unit but it's not actually a USB interface.
All the centre console and what not is out at the minute and i've half a dozen cables to run for gauges and what not so perhaps next week i'll get it installed or at the very least have all the wiring done.
i personally prefer the old blitz spec s and spec r boost controllers over the old greddy ones.
looks nice too in black
mappable boost controller, only really need on high hp cars IMO that require bit less boost in lower gears to avoid wheel spin.
but thats just me.
im sure there awesome, but im super happy with a 15+year old blitz.
azznwab wrote:A upgraded intercooler is what i was intending to do next anyway, i was just aiming for 15 psi because this is what it was boosting at when i brought the car last year.Then the car dropped boost to about 12 to 13 psi and it sounded like a leak that was pulsating, so after a bit if digging on the net i brought a cheapo ebay mbc so i could set back at 15 psi and block off t-vsv.
This is why i assumed 15 psi might of been ok and why i was asking for a general feeling on the subject.![]()
Thanks for reply
sure this is not ambiant temp related?? its been hot the last few months.
warmer weather usually see less boost.
I will have a greddy profec B II for sale in a couple of weeks if you're happy to wait.
Only selling as upgrading ECU with inbuilt boost control.
Thanks for reply
So, if I'm reading that right, you tried to fix a boost leak or sensor issue by bodging in a cheap manual boost controller?
Not really the normal method for problem solving, chucking money and mods at it.
All you have done is masked an issue that may well be getting worse and you still don't know what the issue is.
Please do find the original problem, fix that then look to push the limits of boost.
BTW the stock intercooler is a bit rubbish at stock boost, going over 1 bar isn't going to make it any better.
