As per title I managed to shear off one of the bolts on the rear top mounts whilst fitting yellow billies, so question is do they do replacement bolts or is it new top mounts
Cheers all
If you see an MR2 with a raised engine cover, the bottom line is it's probably faster than your car.
The shocks I've got here there replaceable, they split with a spline fitment similar to wheel studs. I've a couple of old shocks I could probably remove one from
