Whats best course of action..help please
[email protected]
Post by [email protected] »
The car has been modded, but have no idea to what level and current boost.
the bits i do know ..
dastek unichip (blue casing) and smaller box taped to it?
manual boost control (engine bay) looks oldish
foam cone filter
de-cat and bigger exhaust
suspension, front lower than rear(springs)
car drives ok albeit v noisy cabin until turbo spools ??
body works good,interior got retrimed leather from rev3 recently, except needle goes awol off end of dial?
16" rotas with proxies
no smoke,rattles or crunching noises, besides suspension! all seems ok.
got the car cheap £1.800 low milage an quick
was thinking, suspension first (cheapest option ?? ) but unsure what then
Any advice or suggestions would be appreciated on issues etc.
spent 10.000 on last one and really want to keep this one minimum cost.
Amebb
Re: Whats best course of action..help please
Post by Amebb »
I guess the only way you can tell what the engine output is, to put it on a dyno and take it from there.... otherwise its very hard to be precise on the performance and engine output.
'Honest, seriously, this wont hurt a bit ..... there you go........ 5h1t!!! he's dead!!........ Well, you should'nt have touched my Mr2 !!'
alanmr2turbo
Post by alanmr2turbo »
So the last guy fitted a manual boost control without fitting a boost gauge? :lol:
That's the first thing i would be looking at doing if I was you.
2mad
Post by 2mad »
alanmr2turbo wrote:So the last guy fitted a manual boost control without fitting a boost gauge? :lol:
:shock: That is pretty scary .... hope its in spec :pray:
androo007
Post by androo007 »
You spent 10k on a build but don't know what to check? Surely not..... :twisted:
Hez
Post by Hez »
Yeah as above but anyway if your keeping costs down you might aswell give it a good service, give the suspension and brakes a good looking over and when your satisfied with the servicing run it at 1 bar and have a nice fast fairly reliable car. :thumleft:
Hez
Post by Hez »
and either get the unichip looked over or stick a standard ecu on it once you have a boost guage and the boost set.
Post by Martin F »
androo007 wrote:You spent 10k on a build but don't know what to check? Surely not..... :twisted:
HaHa, My thoughts exactly :?
[email protected]
Never said i didnt know what to check, and its because i spent 10.000+ on my last one that i now want to do the opposite !
anyone can make a 385bhp car that looks and go's well with £10.000+
And that was 10yr ago !
my question was best course of action
ie simple ebc instead of mbc + gauge ( hate unsightly gauges)
suspension, cant drive or test safely ..so should i do first and whats the cheapest set for all 4 corners , without rattling my spine like the driftworks coilovers.
or rip it all off n back to stock, which i'd least prefer as its running ok at moment, albeit unknown power,boost,etc.
or ???
would prefer only to pay once for dyno run
so instead of been narrow minded tossers with comments,why not help me get my mr on the road with as much grin factor,safely and with minimum expenditure.
gnzyza
Post by gnzyza »
Presuming your running stock turbo/injectors. Get a boost gauge installed pronto. Compression test the cylinders. Sounds like its got bolt on mods and uni chip, so after getting a ebc and boost gauge if your happy with the power get it dyno'd to make sure it's a healthy tune.
Suspension wise yellow bilstein with decent springs is a good compromise and then you can look to poly bush it if you want to refresh the whole lot.
[email protected]
THANK YOU
to those with useful/interlectual replies.
maybe i should re phrase so as to include all though.
cheapest way with least messing,using whats on car.
wanna get out n upset boy racers without killing me or the car.
besides lookin cool... its all about the speed.
why the f'k get one if not eh ?
[email protected]
gnzyza wrote:Presuming your running stock turbo/injectors. Get a boost gauge installed pronto. Compression test the cylinders. Sounds like its got bolt on mods and uni chip, so after getting a ebc and boost gauge if your happy with the power get it dyno'd to make sure it's a healthy tune.
was thinking along same lines combined ebc/gauge, service, not considered compression test tho, cheers for mentioning.
bilsteins are great but not pocket friendly, budget including dyno,fitting,ebc, etc etc got to be under £1000, if i can get it down to £700 tho ???
SonicSW20
Post by SonicSW20 »
Not a chance of getting a Bilstein setup for £700 - you need springs and top mounts on top of that, and really you should refresh bushes, ball joints, drop links etc at the same time.
androo007
Post by androo007 »
There's a greddy profec Spec B EBC for sale on here now.... cannot go wrong with that EBC
[email protected]
when i said £700-£1000 thats for everything!
It's not that money,or lack of is the issue,
i've thrown excessive time and money on a build once.
800 miles in 2yr and thats including running in engine twice.
then had to sell due to circumstance ( gutted)
not a keeper just one summer, let next person spend his money,not mine on getting the best.
2barGee
Post by 2barGee »
BC coilovers are about £650 and are great as you can adjust the damper settings to suit how hard you want the ride! So soft when you've got the mrs in and then hard when you want to go fast round the twistys!
You could pollybush it yourself for around £100- £150 at the same time if you can be bothered but its a dirty smelly job.
EBC £150-250 use that as the boost gauge as well.
Dyno run £50
Sorted 8)
Get some picture up of your car sounds like a bargain!!!
rgb
Post by rgb »
what needle goes awol . the stock boost gauge does work if its running too much boost the needle goes right off the clock
[email protected]
Its the speedo needle,all other dials n stuff is ok.
its also got a white face overlay in kmh, ??
Post by Martin F »
I would have happily advised you and was even about to welcome you to the site however if that's you showing your colours 3 posts in I will be doing neither =;
[email protected]
WHATS BEST COURSE OF ACTION..HELP PLS
no problem, thank you for sharing your "comment" ??
..... :clap:
