Wondering how people are fitting their over shoulder harnesses to their cars, I've seen harness bars which look pretty good, does anyone know where I could get some of these?
Jasmine
Danbob wrote:Most people bolt up directly to the bulkhead behind the seat using spreader plates.![]()
It's a
little bit more work, but it's cheaper than a harness bar and in theory safer also.
The rear bulkhead is triple skinned steel, so with the spreader plates is plenty strong enough, and you have freedom to set the eye bolts at the correct level.![]()
The other side of the panel is quite accessible, you just have to remove some of the heatshield and some insulation to get to it.
The spreader plates do not necessarily have to be welded on.![]()
Some harness manufacturers specify to hold them on place using sealant to prevent leaks and let the eyebolt do the rest.
Other people prefer to weld them in.
As long as the load is spread it's OK.
Make sure you use a lock nut or 2 to secure them.
They are only a few
££ from demon tweeks.
Harness bars are usually only designed to lift the harness to sit at the correct height, not to take the full load of the belt.![]()
There might be some mr2 harness bars out there that are properly designed, but there are lots of horror stories to be found on the internet.
If you do use one make sure it is a properly designed and tested one!
