Hi all,
Where can I purchase a set of genuine trd springs for my mk2? Any pointers or should I see if Toyota has a set? [/list]
TRD springs?
TRD springs?
Mk1b 1989 Mica Blue
Mk2 rev3 1993 NA Turquoise
Mk2 rev5 1999 Cosmos Blue with st215 conversion 😉
Re: TRD springs?
The TRD springs are not available anymore!
It will be hard to find some used ones... good luck!
Re: TRD springs?
So what's the next best set of springs to get as the trd springs dropped the hight by 1" iirc and stiffens it up a bit so....yea what's the next best thing in your opinion
Mk1b 1989 Mica Blue
Re: TRD springs?
Nic wrote:Eibach Pro Springs
I out the Eibachs on my SW, while the ride and handling was great, they definitely didn't lower the car. If anything they put the car back to factory height, so after replacing old springs they actually made the car higher.
Re: TRD springs?
This is mine with black Bilstein dampers and Eibach Pro springs fitted to give you an idea of the ride height.
Re: TRD springs?
Can you still get the Eibachs?
Re: TRD springs?
ruth11 wrote:Can you still get the Eibachs?
They seem to be available again now in the US.
Re: TRD springs?
Nic wrote:ruth11 wrote:Can you still get the Eibachs?
Yeah, seen them on US sites but not here... I'm in the market for something and can't decide what to go for!
Re: TRD springs?
There are also Suspension Techniques or ST and H&R springs. If you dont mind waiting swift make some springs that are highly rated but youd need to import from japan.
