Mr2Owner wrote:I removed the 2 horns from the car, they are a single wire setup so I assume they earth through their brackets or mounting bolt.
With the horns removed when I put 2 jumper wires on them to test them directly off a car battery, I put the pin to the positive and the bracket to the negative of the battery,should they beep when testing like this?
Will the negative of a battery earth them, or do they have to be earthed to the chassis of the car?
Nic wrote:Mr2Owner wrote:I removed the 2 horns from the car, they are a single wire setup so I assume they earth through their brackets or mounting bolt.
This current thread on the subject may be of help http://www.mr2oc.co.uk/forums/41/164427.html
I've just had a pair of these fitted on mine, they sound a LOT louder and deeper than the standard horns.
http://www.ebay.co.uk/itm/331404028157
