TE37 MR2s
mr2nut123
TE37 MR2s
Post by mr2nut123 »
I'm looking for some TE37 style alloys. So far I've found that the Rota Grids and JAPAN RACING JR3s are very similar. Anyone had any experience of these, and do they fit the MK2s?
Also, is it right that the MK2s PCD is 114?
Would these fit? http://www.ebay.co.uk/itm/4-x-Rota-Grid ... SwwbdWQaCp
Re: TE37 MR2s
MR2 PCD is 5x114.3
Center Bore is 60.1mm
Ideal sizes for the MR2 is:
17x8 front ET35-ET38
17x9 rear ET35-ET38
The lower the offset on the rear, the more chance of requiring the arches rolled.
You'll struggle to get a 17x8.5 ET30 (As per your ebay ad) on the front of a MK2.
Anything bigger than 60.1 CB and you'll require spigot rings to centralise the wheel onto the hub.
mr2nut123
Re: TE37 MR2s
Post by mr2nut123 »
RedMR² wrote:MR2 PCD is 5x114.3
17x9 rear ET35-ET38
Ah ok, cheers Red :thumleft:
I wouldn't mind having 16" wheels if it meant I could get some alloys that looked like the TE37s. I've always loved those style in a deep or matte bronze.
Draven
Re: TE37 MR2s
Post by Draven »
Its all great getting 16" inch wheels it is then the issue of trying to find some decent rubber for them :(
mr2nut123
Re: TE37 MR2s
Post by mr2nut123 »
Draven wrote:Its all great getting 16" inch wheels it is then the issue of trying to find some decent rubber for them :(
Very good point!
Re: TE37 MR2s
17x9 rear ET35-ET38
No problem mate :thumleft:
As Draven said, 16s are better to have than 17s, but tyres are easier to get hold of for 17s.
mr2nut123
Re: TE37 MR2s
Post by mr2nut123 »
17x9 rear ET35-ET38
The car in question would be a TOMs car if I did get another, would that allow more room with the kit, or is it the top of the arch that's the problem?
Re: TE37 MR2s
It's the arches and strut clearance mate. Tom's kit will have no bearing other than making wheels look smaller than ones that would normally look ok on a stock MR2, i.e. 16s
mr2nut123
Re: TE37 MR2s
Post by mr2nut123 »
RedMR² wrote:It's the arches and strut clearance mate. Tom's kit will have no bearing other than making wheels look smaller than ones that would normally look ok on a stock MR2, i.e. 16s
Ah ok. IT is my thing and it's been a while since I've had one of these :wink:
Inovit ST16 looks like the winner! Hope they fit :pray:
http://www.inovit.com/Web/ProductDetail ... 7E97DF18A3
Re: TE37 MR2s
CalMac
Re: TE37 MR2s
Post by CalMac »
It doesn't look like the Innovit wheels will fit tbh, unless you run a square set of 17x7.5 all round which isn't ideal.
You could go crazy and run 17 fronts with 18 rear though, double staggered - 18's are a bit big for MR2 imo.
I haven't found getting tyres for 16's is too bad, managed to pick up some AD08R's in the right sizes but they are quite pricey. Check out Camskill for tyres :thumleft:
mr2nut123
Re: TE37 MR2s
Post by mr2nut123 »
RedMR² wrote:Also check out:
http://www.rarerims.co.uk/
Very good heads up. Did a quick search on these and it would appear they know the MR2 community very well. I'll keep you posted. 8)
mr2nut123
Re: TE37 MR2s
Post by mr2nut123 »
CalMac wrote:It doesn't look like the Innovit wheels will fit tbh, unless you run a square set of 17x7.5 all round which isn't ideal.
It also looks like their UK site doesn't work anymore either. Gone bust maybe..
shinny
Re: TE37 MR2s
Post by shinny »
Very good point!
AD08s for <£100 a corner :thumleft:
shinny
Re: TE37 MR2s
Post by shinny »
Also, what's wrong with the genuine article? :wink:
mr2nut123
Re: TE37 MR2s
Post by mr2nut123 »
shinny wrote:Also, what's wrong with the genuine article? :wink:
Image Replaced With URL For Quote http://shinny.co.uk/photos/woodley.13.jpg
Nothing, but I can't afford them :(
mr2nut123
Re: TE37 MR2s
Post by mr2nut123 »
http://www.ebay.co.uk/itm/JAPAN-RACING- ... 41a2c8740d
He told me that these fit the MR2 ok. Quite nice looking!
shinny
Re: TE37 MR2s
Post by shinny »
Well, beware cheap copies... Rota grids should be fine but wheels need be be strong as well as pretty ;)
Re: TE37 MR2s
Totally agree about the genuine article. However, TE37s are not readily available second hand, even more so in the perfect MR2 fitments.
Plus, a brand new set of TE37s with no tyres would be into the thousands.
I was looking for TE37s as I love them, but couldn't find any, so settled for staggered 17" Enkei RP01 instead :mrgreen:
alan_uk
Re: TE37 MR2s
Post by alan_uk »
Ive also just bought a genuine set of te37's i love them
But i went big ass 18"s so that i could fit my giant new brakes lol
