Rear Lights - Fog Light Modification
Is there a how to guide that explains how to modify the standard rear lights to include the rear fog light?
Re: Rear Lights - Fog Light Modification
I'm interested too.
Something I've been meaning to do for ages but never got around to looking into
I believe there is a guide on the oc in
'know your 2' to do it with diodes.
Here you go
link for how to guide
Make sure you fit the diodes the correct way around as these
"one way" devices are needed to keep the brake light power feed isolated from the fog light power feed
Paul
Paul
Until now I never gave any thought to what the rear lights were doing.
but this quad light mod looks awesome!!
Shame I suck at electrical stuff though.
Pauln wrote:Here you go
Make sure you fit the diodes the correct way around as these"one way" devices are needed to keep the brake light power feed isolated from the fog light power feed
Paul
Thanks Paul
As above until I read this thread I never even gave the rear lights a thought, thanks for the link another job on the to do list.
Or you could just use one of the reversing lights, that way you could still have four tail lights and four brake lights, looks well better Imo
Martin F wrote:Or you could just use one of the reversing lights, that way you could still have four tail lights and four brake lights, looks well better Imo![]()
But other than when you switch on your rear fog lights, that's exactly what you can have with this
Paul
But then it looks like you've a blown reverse light bulb.
My car failed the mot a few years ago doing this as it was just a pale pink glow
Diodes or relays ftw
RedMR² wrote:Martin F wrote:Or you could just use one of the reversing lights, that way you could still have four tail lights and four brake lights, looks well better Imo![]()
But then it looks like you've a blown reverse light bulb.![]()
My car failed the mot a few years ago doing this as it was just a pale pink glow![]()
Mine past mot with this mod
The four and four are worth these hassles, are they not
According to that guide the two inner lights are already wired up as rear fogs.
Why don't mine work as fogs then?! Mine's had one of the standard aftermarket foglights cable-tied on the rear exhaust grille
- why would the importer bother doing that if it supposedly already has rear fogs wired up?
I like the idea of having all four lights as driving/braking lights though
Imports don't have rear fog lights, hence the additional one that some bolt to the grill.
Agreed, Gotta have four and four.
There's just better ways than converting a reverse light.
My set up has four tail, four brake lights, and inners as fog lights, complete with illuminated us red triangles.
I have relays wired in that disengage the inner lights as brake lights when the fog lights are in use.
In addition, I have 2 reverse lights
RedMR² wrote:
Agreed, Gotta have four and four.There's just better ways than converting a reverse light.
You are so right looking at it that way, it looks ridiculous and is very impractical, I just have it because that is the way it was when I bought the car
As has been said, that guide is based on the assumption that the inner pair of lights is already fitted with a dual filament lamp, so all four lamps act as tail/brake.
But what is actually fitted to your car will depend on the model and whether it has been modified over the years.
Rev 3+ UK models also have a different reflector in the inner pair
If you already have dual filament lamps in the inner pair, you just need diodes
Personally I much prefer to have two reversing lights, the streets around our way are badly lit at it is and parking spaces are at a premium.
If your fitting rev 3 lights to a rev 1/2, you also need to be aware that the connectors at the end of the wiring loom on rev 2 lights are different to those fitted to rev 3.
Personally I opted for re-using my rev 2 loom and the careful use of a Stanley knife to ensure the rev2 holders were a good fit in the rev 3 lights and locked firmly into place.
As the original guide I linked to no longer seems to be available, I've included an updated version of the wiring diagram that was included in that guide in case it helps others.
Paul
I had mine set up with dual filament bulbs like:
tail lights
- all four came on
(dim)
brake lights
- all four came on
(bright)
fog lights
- inner lights came on
(bright)
(and outer lights were also on dim, as foglights can only work when when headlights on)
Obviously if you braked while foglights on then it just looked like the outers did anything.
And I had a switch that disabled the inners being on for both tail and brake lights, but kept them for foglights
- just as per original UK spec
tail lights
brake lights
fog lights
Pauln wrote:As Red said, that guide is based on the UK model which only uses a single element bulb in the inner pair as a fog light.The UK model also has a different reflector in the inner pair
(sometimes called a half moon reflector).
This doesn't fill the entire lamp housing, so it's easy to see which you have.
The JDM models have twin filament lamps in the inner, so you have 4 rear lights and 4 brake lights
If you already have JDM rear lights, you just need diodes(or a relay if you prefer) to make the inner pair rear, brake and fog.
If you have UK rear lights you also need to change the lamp holders on the inner pair.
Paul
Mine didn't.
The JDM models have twin filament lamps in the inner, so you have 4 rear lights and 4 brake lights.
Paul
Glad I read this otherwise I'd have bought bulb holders too! Result!
