I am also replacing the coolant and t/stat as it had a new rad recently, Aluminium.
but It stayed on the C mark on way home, so think the stat is stuck open.
Got some new oil and a filter, so best to be safe rather than sorry.
Also going to give it a brake refurb, pistons, seals and pads
+ disks and h/brake cables.
What I want to do to the car is:
Side Scoops,
Some light window tint on rears,
Air scoop roof
Polyflex purples all around as it deserves it.
Decat on the n/a as it already has what I believe is a mongoose exhaust
(any way to tell, it's definately aftermarket)
New steering wheel as stock one has been painted with spray paint
:O
Needs a new downpipe.
Get some 160mph clocks and a SLD for the turbo conversion.
Some 10" subs behind seats
LED dash bulbs
(never liked the yellowy look)
Timing belt
+ w/p
+ oil pump?
+ idler pullers
Some choice gauges IE water temp.
A shifter bearing kit just to take some play out.
After all that, it'll be a turbo conversion.
Which just off of ebay
(i'm sure I could find parts cheaper elsewhere) Including the engine with 80k km on it.
Came to just below
£2k so I may end up doing this up or a may buy a turbo.
Not sure, as it is a nice shell.
Needs new cancers bars but the Sills are good!
Also the t-tops are not leaking but I will most likely sort the seals out as a precautionary.
I like knowing things are not going to fail instead of waiting and playing by chance
Let me know what you think guys
Any opinions or suggestions would be greatly appreciated.
