need some help with the vacuum pipes on my car.
the car does not have the VSV or EGR installed and am thinking to myself where do all the pipe work go erk.
hopefully someone can shed some light on this please?
thanks
lookieuk wrote:Ok cool thanks
That makes more sense now
Pipe 1 is showing the two feeds off the turbo pipe
What would go here??
bobhatton wrote:lookieuk wrote:Ok cool thanks
Nothing should go on them, all lines should come from the manifold.
jimGTS wrote:bobhatton wrote:lookieuk wrote:Ok cool thanks
if there isnt a feed directly off the turbo(to control the wastegate), you can use one of them surely.
its the same thing.
its the same thing.
Rob - East Coast Imports wrote:
The line to the bottom port on the ext wastegate shouldnever
Completely wrong
Completely wrong
