[Mk2] [Turbo] Brake master cylinder help
Dannyc
Post by Dannyc »
Could someone point me in the right direction , I am pretty sure my bmc has given up I have Rev 3 brakes fitted on a Rev 1 turbo with abs so can I just fit a Rev 3 turbo bmc. Also do I need to change the servo or will it bolt on my Rev 1 servo. Thanks in advance Dan
Dannyc
Re: [Mk2] [Turbo] Brake master cylinder help
Post by Dannyc »
Also trying to find out is there and difference between the abs and non abs brake mc?
MartinF
Post by MartinF »
What makes you think it has given up?
No problem to use your original servo.
Blue Lexus RCF
Black MKIV UK Manual Supra
Green MK2 MR2 Tin Top
