Rev1 Auto (Sorry) Speedo and Overdrive Light Flashing
gmac90
Post by gmac90 »
Evening all I have got a Rev 1 Auto NA :oops: and Everything was fine when I was driving and then all of a sudden I noticed that my Overdrive light was flashing at me and my speedo had stopped working anyone had this problem or know of anyone that has ? cheers guys
madbasshunter
Re: Rev1 Auto (Sorry) Speedo and Overdrive Light Flashing
Post by madbasshunter »
I believe the flashing od light is to tell you there is a fault in the system, presumably the speedo cable as the speedo has stopped. The back up speed sensor is built into the speedo.
http://www.autoshop101.com/forms/h17.pdf
http://www.autoshop101.com/forms/h16.pdf
RyanRs wrote:
Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously , you don't know the answer to this? and you call yourself a car mechanic :shock:
benjo
Post by benjo »
Hi had this fault years ago o/d light flashing because speedo not working.
If it's import auto like mine and it has a converter (km to mph) between gearbox and speedo
Cable this was the cause if so take converter out put speedo cable straight into gear box test drive if speedo works fault found :thumleft:
