Starting up the car, it took a little longer than usual before igniting and starting, where I had to then put a little throttle in and it would pick up and start, because the car would almost die if I didn't feel fuel into the car.
I recently had an incident with running out of fuel, and before you laugh, my fuel gauge is apparently inaccurate, as I wasn't even on empty and she ran out.
However, I knew I had loads of fuel because I had only done 40 miles since a 40L fill just a couple of days ago.
Any ideas as to what this could be? It does actually happen more often than not.
99ron
