alex687 wrote:Got my"standard" ct26 back from TT today and thought I'd share with you a load of pics.
http://i1300.photobucket.com/albums/ag8 ... swsjts.jpg
http://i1300.photobucket.com/albums/ag8 ... ano4gr.jpg
http://i1300.photobucket.com/albums/ag8 ... ekj7dd.jpg
http://i1300.photobucket.com/albums/ag8 ... 6eqkij.jpg
http://i1300.photobucket.com/albums/ag8 ... zu6mnd.jpg
The perspective makes it look wrong but the verniers are near enough inline with the inner diameter of the exducer.
http://i1300.photobucket.com/albums/ag8 ... nycoif.jpg
http://i1300.photobucket.com/albums/ag8 ... 112e9h.jpg
http://i1300.photobucket.com/albums/ag8 ... quhqer.jpg
http://i1300.photobucket.com/albums/ag8 ... hb7pcu.jpg
http://i1300.photobucket.com/albums/ag8 ... gsjxdf.jpg
http://i1300.photobucket.com/albums/ag8 ... d1c1jk.jpg
as you can see, the turbine has seen better days.both the turbine and compressor are not magnetic
- that mean they are ceramic?.
TT told me it had a ceramic shaft.
looks and feels like steel to me and it is magnetic.
Any help identifying whether this is a hybrid or what's been done to it much appreciated.TT told me the compressor wheel and housing are standard but having done plenty of googling I have to disagree.
Bob I'd like to send it down to you as you seem much more cooperative and helpful that TT but at the same time I would ideally find somewhere more local where I can take it in and speak to someone face to face.I am off away this week so will have to put it on hold for a bit either way
mr2magic wrote:The turbine surely isn't stock, bob.
mr2magic wrote:Just take a ganders at the cast'nut' on the turbine.
.every oem turbine i've ever seen has a 10 point, this one has only 6 ergo hex.
bobhatton wrote:mr2magic wrote:Just take a ganders at the cast'nut' on the turbine.
I see so many, I shall have to go and have a look and some.
alex687 wrote:yea the 11 blades doesn't seem to be stock looking at google images.Anyway I'll have to send it down to you bob and hopefully you can do some magic
bobhatton wrote:The turbine is the same as a steel replacment but the comp wheel is bigger as can be seen in this photo with the comp housing fitted on a stock wheel.
alex687 wrote:bobhatton wrote:The turbine is the same as a steel replacment but the comp wheel is bigger as can be seen in this photo with the comp housing fitted on a stock wheel.
But all stock turbines i've seen only have 10 blades..
Is the compressor in good enough condition to re use?
2mad wrote:Compressor looks a bit lost in the intake.
maybe go for something a bit bigger
alex687 wrote:I got confused myself cos I didn't look at who was posting.I thought it was bob saying my comp wheel looked lost!
Whats the plan then bob? what parts need replacing? Can you get hold of an identical turbine wheel? would you recommend clipping it? and can youport the wastegate without too much trouble?
