Engine mounts for a track car... Which ones?!
J-1
Post by J-1 »
I'm looking for good engine mounts that's suitable for my track car, but not sure which ones are worth buying...
I've found these, but reluctant to blow 350 quid on them.
http://h-tune.co.uk/innovative-steel-en ... sgte-sw20/
Is there a cheaper, but equally durable engine mount kit on the market that's been tried and tested?
Appreciate any advice!
Race Idiot
Re: Engine mounts for a track car... Which ones?!
Post by Race Idiot »
Arent those both the same kit?
Those look pretty neat, i'd be looking at those if I didnt have my trd mounts. They seem worth the money seeing as they come with brackets and not just the inserts like most.
Isnt the cheapest option filling the std mounts with urethane
https://www.youtube.com/watch?v=znjx88-xSF8
sky-net
Post by sky-net »
I've been using urethane mounts from Speed Source a while ago.
Pros: I had the feeling that engine power was sent to the floor instantly.
Cons: Big engine vibrations were sent into the cockpit in the 800 - 1000 rpm range.
I think those kind of mounts could suit your needs :-k
jimGTS
Post by jimGTS »
powerflex black series engine mount bushes (for track use).....
i have the largest 83.5mm front and rear.
though i dont think any are available for the sides.
Draven
Post by Draven »
I've got a pair of powerflex front and rear reds already in the mounts.. you can have them for £40
rev2rich
Post by rev2rich »
I have the innovative steel engine mounts and what a bit of kit they are well built and comes with a lifetime warranty. Bolt off the old ones and bolt in the new ones :thumleft:
JAAASH
Post by JAAASH »
Hux Racing solid mounts. Was looking at these today for mine. Might be a bit extreme for a road going car though :-k
_________________
"What the Deuce?!"
My MR2 - http://www.imoc.co.uk/forums/viewtopic.php?t=174494
J-1
Post by J-1 »
JAAASH wrote:Hux Racing solid mounts. Was looking at these today for mine. Might be a bit extreme for a road going car though :-k
I can only see these for the K20 swap?
EDIT: found them!
J-1
Post by J-1 »
JAAASH
Post by JAAASH »
Maybe I won't bother then :lol:
_________________
"What the Deuce?!"
