Can anyone identify these bolts? Fun quiz!
JD
Post by JD »
Alright. I'm a dunce for getting this messed up but can anyone point me in the right direction so i can re-bag these bits?
picture here on cutting mat to show approx scale:
Things that have been removed:
Throttle body + spacer/bracket thing
All things connected to inlet mani
One of the brackets bracing inlet mani to block
fuel rail + fpr and injectors
a few bolts/nuts holding inlet mani to head
Ta
mr2magic
Re: Can anyone identify these bolts? Fun quiz!
Post by mr2magic »
10, 11 and 12 hold the fuel rail to the head
4 and 5 hold the wiring loom to the intake mani
JD
Post by JD »
Thanks, 5 down :)
mr2magic
Post by mr2magic »
8 and 9 probably hold the air pipe brackets (both on the left side of the manifold) to the manifold.
The washer is for the fpr.
pistol pete
Post by pistol pete »
17 to 20 throttle body to inlet bolts
mr2magic
Post by mr2magic »
I thought 17 and 18 looked a bit short for the tb (i assume the raster is 1cm^2)
DB Mr2
Post by DB Mr2 »
2 and 3 look thicker and so maybe bracket/brace bolts from block to throttle body?
4 and 5 could be throttle cable bracket.
JD
Post by JD »
Thanks chaps - bagged up today according to thread and the rest should become a bit more obvious once I start putting things back on :)
mr2magic
Post by mr2magic »
What you can also do is check the markings on the head. Toyota has a system which gives you the appropriate torque value. This can help you find where the bolt belongs.
JD
Post by JD »
Is their anything Toyota hasn't thought of?
On a related note, the other day I asked my neighbour if he had a long 12mm socket I could borrow and he was totally incredulous. He maintained that you just don't get 12mm and 14mm on cars and my problem must definitely be that I'm using the wrong size socket :lol:
mr2magic
Post by mr2magic »
LOLZ!!
Along the same lines:
I was doing suspension and fuel pump work on an older mercedes W124 last weekend and there are literally thousands of 13mm bolts and nuts.
