Problems after car laid up for 5 months
mr2mk2
Re: Problems after car laid up for 5 months
Post by mr2mk2 »
Peter Gidden - SBITS wrote:
mr2mk2 wrote:Found a secondhand afm for £50, Peter, is it worth trying to clean my existing one first before buying an unknown?
You can try cleaning (again).
I wouldn't be buying an uknown. Buy or borrow one from a trusted source.
Do you know of any trusted sources Peter? I will try taking the top off and cleaning the track. By the way, the CSW is broken now so I've disconnected it but not throwing a fault code. Am I correct in thinking this will only.be an issue with cold starts?
Peter Gidden
Post by Peter Gidden »
mr2mk2 wrote:Do you know of any trusted sources Peter?
See if there's someone here local to you that can lend you theirs for ten minutes.
mr2mk2 wrote:I will try taking the top off and cleaning the track.
AFMs should never be dismantled.
mr2mk2 wrote:By the way, the CSW is broken now so I've disconnected it but not throwing a fault code. Am I correct in thinking this will only.be an issue with cold starts?
I've got customers that haven't had a cold start switch for years and had no issues.
mr2mk2
Post by mr2mk2 »
Is there anybody who lives near Barnsley/Wakefield on here who has a rev 1 turbo and would be willing to let me try their afm. I will make it worth your while. Thanks Rob
mr2mk2
Post by mr2mk2 »
Well I've finally decided. I sold my MR2 na which was totally reliable and then I bought this rust free (apart from a small patch on each sill) rev 1 turbo which has been brilliant when running well. However after paying out over £1k for metal hg, HSH and new parts for the ignition system, enough is enough and it's going to the Scrap Man. Will be sad to see it go but I think it's one of "those" cars. Wife calls it The Gnome as it just sits in the garden :)
thomp1983
Post by thomp1983 »
Seems a tad extreme, personally id get it over to Pete as he's near Barnsley and see what he thinks before throwing the towel in
mr2mk2
Post by mr2mk2 »
thomp1983 wrote:Seems a tad extreme, personally id get it over to Pete as he's near Barnsley and see what he thinks before throwing the towel in
May seem a tad extreme but I learnt my lesson years ago, don't throw good money after bad. It's a Yorkshire thing. Heart says love it and keep it, head says get rid. Time to get rid!
