Chargecooler core
Chargecooler core
Post by Martin F »
I would like to get my intake temps down as low as i can, i have the radtec system in the car.
I was originally thinking about putting a 2nd core in between the radtec core and throttle body https://www.frozenboost.com/air_water-i ... 3cd0be2853
but after seeing Craigs chargecooler (RedMR²) i am thinking of getting one similar to fit in between the turbo and throttle body.
I was thinking something along the lines of this... https://www.frozenboost.com/air_water-i ... 3cd0be2853
I have plenty of space without the standard engine lid, would this work ok ? (i can make it fit).
Are frozenboost chargecoolers ok ?
Anybody know of a better option or can give me better advice ?
Thanks in advance :thumleft:
C35Rob
Re: Chargecooler core
Post by C35Rob »
the first one would be fine, the second one is huge, and probably overkill! the main issue I can see with it, would be the angle of hose required to mate the outlet with the throttle body.
this
size wise will be much closer to the style that Redmr2 has..
Are they ok? yeah, I'd say so.. there's plenty of people out there using them and making big numbers
[/u]
bobhatton
Post by bobhatton »
If you want the best, http://www.bellintercoolers.com/
They will make the end tanks to your drawing so you have the best fit
mr2magic
Post by mr2magic »
^1
Bell are awesome! Gerhard will always take time out to give advice for sizing, position, endtank design.....anything really.
