I have an issue where the front discs keep warping.
A few months later the problem then came back.
A few months later and it's back again!
I am really at my wits end with it now.
Any help is much appreciated.
coup27 wrote:I have a friend who works for a motor factors and can get me cheap parts
Rob - East Coast Imports wrote:Are they actually warped though? Have you checked the discs for runout?
Gazza_DJ wrote:The fact that the problem keeps coming back after a couple months suggests that you aren't bedding in the brakes correctly, or at all.If you do not bed them in correctly, you'll get an uneven transfer layer on the discs that will get worse with use as it builds unevenly.
This will cause vibration.
