I actually have a HKS evc 1 i'm keeping safe, hopefully be worth something one day
2mad wrote:Got the same boost controller.
i hooked up trottle and rpm when i installed on the mr2 but found it was not needed
i didnt need rpm or throttle baced boost so didnt bother when i fitted it to my st205
the unit still works great
, setting up stock actuator boost is a pain but after that all good
Bumble-bee wrote:2mad wrote:Got the same boost controller.
Hey man! Since you've used this could you run me through what setup should be on it? Just for running stock and then what each part means as the manual speaks in another language to me and I don't want to se it to something that will blow up:')
Bumble-bee wrote:Want to come and do it for me?:') im only 19 and I love speed but I'm too clueless as to what to do to set this up properly
