Hi there,
I took a car to a tuner and before mapping he did a boost leak test and we found some leaking point around silicons, tightened them, but there is still a huge amount of air coming from around intake manifold.
We can't feel the air with hand, but it's clearly heard.
We still did not check from under the car.
I am using Cometic gaskets
(they ar thin paper gaskets) and because we are going to take intake manifold off, I've ordered OEM gaskets.
Are Cometic gaskets such a crap? Should OEM gaskets solve this boost leak?
Now when we fill the system
(blowing from the air filter location) with air, pressure drops from 0,5bar to 0,2bar very fast and then it takes some seconds to drop to 0.
What else should I check or do when we will be changing gaskets?
Thanks!
