Hey Paul, thanks for jumping in, I do appreciate your time.
Had the car a couple of months, took it on as a project.
It didnt run due to the iridium spark plugs it had not providing a big enough spark.
Changed them for NGK copper(Meant to ask someone my Rev1 was listed with BK5's, where as alot of people on here have BK6's?) standard bad boys and it ran sweet as a nut, drove it a few times on a private road and loved it!
MOT time, it needs nothing to do with engine, so I fix all the parts needed for retest then the fun begins.
So a couple of weeks ago Im running late for the retest so I jump in, start the car and straight away its running like a bag of spanners, its never ran lumpy like this before, it wont build speed outwith 1st
& 2nd and even then is really poor, the turbo sounds like its at/near full boost(Im sh*tting my pants at this point) then BANG!
The car backfires louder than any backfire Ive ever heard and it rolls to a stop blocking traffic
I keep starting it.
Car idles but dies as soon as I touch the throttle, after plenty of head scratching I find a 20p sized hole on the underside of the silicone connector to the throttle body(I assume from the backfire) and its burst one of the plastic vacuum diaphrams below the stock bov.
I swap the silicone connector with a spare and tape up the diaphram
- the car drives again
Its still lumpy and not accelerating well at all, 10mins later(still trying to make my retest on time, lol) the car just dies and nothing happens when I try to start it
- at this point Im seriously considering chucking a match in it and walking away.
.AA arrives and we find out its chewed the timing belt
I didnt make the retest
Now I do all my car jobs on my drive so the 3 jobs I REALLy didnt want to tackle on the MR was it's timing belt, clutch and headgasket.
So AA tows me home and start stripping it that night.
It takes me a week, doing bits before work and bits after(a few 3am finishes) but I change all three belts and the water pump which was leaking coolant(probably what weakened my original timing belt).
I get the timing marks from Peter(Cam pulley leg with the hole lined to the vertical indents on the engine case behind and crank notch lined up to 0deg on cam cover) and put the thing back together, now Im no mechanic but Ive done a few timing belts before and outwith lack of space, I didnt find anything particulary difficult on the MR.
I put the mounts etc back on, turn it over and thats all it does.
At home I was getting fuel and spark.
Since being in the auto electricians the fuel pumps fine and working as it should, the clifford alarms not stopping anything and Im getting fuel and spark but it wont run.
The auto electricians a bit stumped.
This week he's moving onto mechanical checks.
Compression
Timing check
The guy is working on my car when he's seen to the higher paying jobs that come into his garage each day, which I can appreciate as it helps keep my costs down but the downside is progress is sllooooww and Im concerned its been a while since he's worked on anything like the MR.
I could be wrong, its just a gut feeling.
I had water in my boot at the time the timing belt went and I def heard a different sizzling noise which seemed to be coming from my Fuel Pump/relay area.
The AA mechanic said it was prob the relays powering down.
.just mentioning it as obviously the ECU is in the boot but I tried a spare ECU I have and it also did nothing(although Im not sure it even works as I got it with the car).
Thats the back ground, every detail I can think of that may help you diagnose whats happened.
I am worried that the compressions the issue as an engine rebuild wouldnt be financially feasable but at this stage thats just speculation until its checked out properly.
Any input from a specialist is greatly appreciated
