New Tbar Seals - Is special sealant required?
Rev3-MR2-Turbo
Post by Rev3-MR2-Turbo »
I'm fitting new bar seals for the body, the bars and also new door seals.
I know the new seals come pre-applied with some sealent in certain places but do i need to buy my own sealent too?
I want to get the best result possible so if you can recommend a sealant please do let me know.
Peter Gidden
Re: New Tbar Seals - Is special sealant required?
Post by Peter Gidden »
No additional sealant necessary.
Draven
Post by Draven »
Peter Gidden - SBITS wrote:No additional sealant necessary.
This... :thumleft:
Rev3-MR2-Turbo
Cheers, all the new rubbers arrived today,
- Tbar seals
- Doors/Window Outer Seals/Weather strips
- Door seals
Would it be a good idea to take them out the plastic bags and give them a good polish with silicone spray or anything else that you would recommend?
I want everything to be perfect.
When i remove all the old rubbers/ weatherstrips whats the best stuff to clean all the old gunk with and again once cleaned should i spray silicone spray all along the channels before fitting?
i'm thinking it will be a good idea and couldn't hurt.
