Suspension & Wheels - Fitment/offset question
juliankv73
Post by juliankv73 »
Hi
Long story but I need to sort my Dads suspension as his shocks on his MR2 are failing.
My Dad was going to fit Meister R's but has decided not to.
I was going to put on my Desmonds Wise wheels on his 2.
But will 17" x 8" et35 and 17" x 9" et38 fit on a Mk2 with stock suspension?
Im thinking the rear arches would need to be rolled, but am concerned about whether the wheels would clear the struts :-k
Cheers Julian
C35Rob
Re: Suspension & Wheels - Fitment/offset question
Post by C35Rob »
they'll fit no problem, look at my build thread.
juliankv73
Rob85 wrote:they'll fit no problem, look at my build thread.
Thanks Rob, my fronts are 8J
From reading the for sale ad your fronts were 17x7,5 et36 front :-k
So I'm guessing an 8j et 35 on the fronts will be flush and no rubbing?!
C35Rob
Post by C35Rob »
correct, there's more than 1/4" between the inside of the rim and the strut though, quite a bit more.
in fact, you're more likely to encounter rim-to-spring issues with adjustable coilovers, since the OD of the spring is bigger (and therefore closer) than the OD of a fixed spring platform damper, where the spring platform and spring sits above the tyre - the only issue you'd run into there is if running (incorrect) tall tyres like a 225/45 as opposed to a 215/40 you may rub the tread of the tyre on the bottom of the spring cup
C35Rob
Post by C35Rob »
thats with a 215/40 and a set of old KYB gymkhana dampers (due to be replaced...)
juliankv73
Thanks Rob :thumleft:
That's great mate, Ill get my Desmond's out of the loft and onto my dads v6 \:D/
