I have a 92 turbo, it has only done 78000 miles and been stood off the road for 4 years due to us having another child.
Obviously after that long off the road she needed a little TLC.
I have changed all of the brakes front and rear including the callipers.
My first problem is that on the way back home from fitting the brakes, the brake fluid warning light came on, though I would be able to limp to the garage to get a top up, but a few miles later the engine management and TRC light came on together.
Now the TRC will not cut in, the light for the ABS and TRC come on and go out as they should on start up, any ideas?
Can you bleed the TRC/ABS system?
If so please tell me how?
I will seek advise on my other issue separately.
Thanks.
