Got trouble steering!!
TUR80
Post by TUR80 »
The power assisted steering is starting to make a noise and the steering tightens up and then releases every time you turn the steering wheel especially when going right hand down?! Feels a bit dangerous to drive confidently. Would anyone know what this could be as I need to get this sorted ASAP. :shock: :shock: :shock:
Also where is the Power assisted fluid res located? :-k
I bet this is gonna cost! Its a shame, I seem to have a different problem with each MR2 I buy. ](*,)
I suppose its a learning curve.. :study:
pnjmcc
Re: Got trouble steering!!
Post by pnjmcc »
Hi Mate,
ISTR its located under the bonnet under all that plastic that hides the battery etc.
Not the best description ever try looking at :-
http://www.mr2-tech.com/bgb/mechanical/ ... eering.htm
Should help
Regards
PaulM
92 G-Ltd.
TUR80
Post by TUR80 »
Thanks mate,
That link is very helpful.
Cheers. :D
