Seal and body work needed. Help
Sonia
Post by Sonia »
Hi. Am Sonia. I have a T bar Mr2 and Am looking for a MR2 specialist to do some refurbishments which includ repair seal and deal with leaks around TBar, top of doors and rear windscreen within Wantage ( Oxfordshire) area or within a reasonable distance. Any suggestions? Thank you
androo007
Re: Seal and body work needed. Help
Post by androo007 »
S Bits
MR2 Turbo Boy
Post by MR2 Turbo Boy »
+1
Peter, S Bits... :thumleft:
thomp1983
Post by thomp1983 »
Did you all ignore the near oxfordshire bit? There's an mr2 specialist that was recommended on here awhile ago there based near swindon at castle eaton
cosmos
Specialist
Post by cosmos »
Nearest i can think of is www.roguemotorsport.co.uk which is 15 miles north of Banbury, near Southam.
Good luck.
Sonia
Re: Specialist
Post by Sonia »
[quote="cosmos"]Nearest i can think of is www.roguemotorsport.co.uk which is 15 miles north of Banbury, near Southam.
Good luck.[/quote
Tried rogue motorsport and they deal with roadsters. Thank you anyway :)
Sonia
Post by Sonia »
thomp1983 wrote:Did you all ignore the near oxfordshire bit? There's an mr2 specialist that was recommended on here awhile ago there based near swindon at castle eaton
Sorry, I am new here and had not seen the Oxfordshire bit. Thank you for the info though, will look into it right now :)
raptor95GTS
Re: Specialist
Post by raptor95GTS »
Sonia wrote:
cosmos wrote:Nearest i can think of is www.roguemotorsport.co.uk which is 15 miles north of Banbury, near Southam.
Good luck.
Rogue only deal with roadsters? oh well, that's a pity. Hope you get someone good to work on your car and bring it up to tip top condition and er welcome to the forum :thumleft:
cosmos
Rogue
Post by cosmos »
Looks like they still do servicing of varying degrees for all MR2's and are known to be a major player since years ago in all aspects of this marque. Perhaps seals are a different situation.??
thomp1983
Post by thomp1983 »
sorry sonia that was aimed at those that recommended peter at sbits. id definitely recommend peter but your post asked for someone near oxon, sbits are about 170 miles up north from wantage
Sonia
Post by Sonia »
Yes, 170 miles is quite a way from oxon. hopefully, will find someone soon :)
markstevieandmads
Post by markstevieandmads »
Castle Eaton vehicle services.
That's the one near blunsdon Swindon.
I've made some enquiries about doing some work to my turbo and they have been very professional and got back to me straight away.
