Anyone Run a Turbo with no boost?
2mad
Re: Anyone Run a Turbo with no boost?
Post by 2mad »
jimGTS wrote:
Marf wrote:
jimGTS wrote:
+1
min you can run is 7psi or 0.5bar
sure you can feather around 0-0.2bar or whatever, but foot down, hi-ish rpm you will reach 7psi.
Assuming you don't have a big exhaust. on my setup (naughty naughty t.b.d downpipe, fujitsubo RM01a exhaust) under full throttle I saw 7psi until 5000 RPM or so, then it crept to 11psi.
oh for sure, most will creep a little with a downpipe and/or exhaust.
some creep alot!
Yeah mine would creep till i ported it (posted pics in the past) .. after .. 0.5 to the redline .. very stable boost after porting regardless of boost pressure :thumleft:
