Mk1Chris wrote:I cant 100% remember, but I think you need to make sure the mk3 box isnt from a jap import as they didnt all have lsd iirc.![]()
I asked God for a bike, but I know God doesn't work that way.So I stole a bike and asked for forgiveness.
kaiowas wrote:Hi Paul,
I'm considering having a go at some of this over the winter.I'm having the kind of traction issues that will definitely be helped by a Torsen LSD and the lower gearing of the 6 speed conversion will be an added bonus.
Mine won't be as posh as yours, I'll probably avoid rebuilding the 6 speed which should keep costs and labour under control.
Can I just check whether it makes any difference whether you source the LSD from a 5spd or 6spd mk3 box and whether you use the 140 or 190hp Celica box(My initial research suggests they may have different ratios in them)?
