Mr2 ecu's have I think two main running modes 1.
bad gas mode, the ecu cuts boost, runs extra fuel and retards timing
(It does this on warm up too).
2, normal operation mode, allows higher boost, leaner fuel and advanced timing.
Basically you could have a problem
(knock) the ecu find bad enough to go into bad gas mode.
On my rev2 setup I had lovehorsepowers knock leds fitted, not sure how to do this with a rev 3
(should be the same just ground an led through the vsv pin).
Does the ecu still allow
full boost
(stock vsv system) when your car is driving poorly.
If its cutting boost this would mean its gone into bad gas mode and its detected excessive knock.
