So you want to improve handling and predictability? There is one simple change that will transform your car more than anything else mentioned in this thread.
R888s!
(Or similar, sticky rubber).
You honestly won't believe the difference it will make!
Of course you might not want to do that on a daily driver as you'll spend more on tyres that last fewer miles and wet weather becomes more of an issue too.
People incorrectly think wider tyres always means more grip.
However, pressure and rubber compound are both substantially more important to grip than whether you've got an extra 10mm width or not, and sticky track tyres are one extreme example there-of.
That said, the best improvement is certainly driver training.
You can improve every car you ever drive by improving yourself
