mr2 rev3 turbo white tintop fast back
lukaharris
Post by lukaharris »
mr2 rev3 turbo for sale
about the car:
white
tin top
staggered 8j 9 alloys enkei 3 spoke rs3 with lots of tread
recent poly bushed all round
i went over the brakes at beginning of the year so no sticking calipers and ebc black pads front n rear,
aluminium radiator
undersealed
stock bilistein suspension
quad rear side lights
leather seats bit worn
rear of sills were rusty so i chopped it out and welded in new plate
bit of rust on drivers door at the bottom (just being honest)
single air duct conversion
i had a issue where the bonnet opened missed the second latch come up and slapped the roof (sounds bad) so i replaced the bonnet but also got the front and rear bumpers resprayed at the same time. There is a dent across the roof but being white its hard to notice and the scuttle pannel ends are snapped off
standard engine and internals
0.4 plugs
magnacore leads
has had new dizzy cap n arm and new coil
modified exhaust manifold to take external waste gate
turbo smart waste gate 38mm with the screamer pipe pointing floor
methanol injection on throttle body and fuel tank in boot
3" stainless induction pipe with cone filter
top speed delimited
gearbox is fine with no crunching gears going up or down the box
exedy clutch
i oil change every 3k miles and its just been done 700 miles ago
ct26 hybrid from turbo technics cost £821
3" straight through exhaust
blitz dump valve
genuine toyota cam belt and water pump recently done
i do have various invoices
TAX till 06/15
MOT till 08/15
V5 present
probably some other stuff ive missed, but any questions then call 07895366372
looking for £1999. located in somerset.
engine bay will be sorted in the next week so put some pics up then :D
lukaharris
Re: mr2 rev3 turbo white tintop fast back
compression test results range between 180psi and 190psi across the cylinders, i have pictures on request.
Tsia
Post by Tsia »
What's going on with the IC setup of this?
lukaharris
Erm top mount by the looks lol
Thinking of taking the mods off and putting the car back to standard as easily done.
Draven
Post by Draven »
How do you see what is behind you when reversing?
lukaharris
Look in the mirror's, like you would a van.
matt-mr2
Post by matt-mr2 »
Does it get hot /heat soak as the air is designed to exit out the top on a mr2 :-k
GLWS
lukaharris
Car is back to standard now along with the standard intake manifold all I need to do is make up some boost pipes for the cooler and its driveable again.
As im removing the boost controller and wideband ill drop the price £2600.
Ill put some pics on in the next few days along with a heap of spares ive got that I need to get rid off.
Tsia
Post by Tsia »
Sounds good, looking forward to pics!
lukaharris
Engine back to standard but needs intercooler spal fan putting on which ill try to do but only takes 5 mins and as you can see mate the roof isn't bad at all.
