My car was running some aftermarket springs with
öhlin dampers.
It had poly bushes all around, and some solid swaybar end links.
I'm currently overhaling the entire car.
I'll be running Eibach sportline springs with the
öhlin dampers
(will be rebuilt and dyno'ed).
Stock swaybar end links.
And then I was hoping on running stock bushes.
The suspension was super stiff before, and I would like a more comfortable ride.
The front swaybar had ripped the mounting points though it looks to be stock.
Will be getting new stock balljoints, and top mounts.
I agree with you on the springs being the main cause, but I also don't want all the road noise, and every little bump going through the car.
I like a good handling car as much as the next guy, but I'm not a pro racer, and with my skills, I probably won't be able to use the car to it's full potential anyway.
