Can someone confirm that it is 66.1 to 60.1 rings I need? I also don't know what wheel nuts I need.
raptor95GTS wrote:if the skyline wheels have a flat face where the wheel nut sits against then you'll need normal OEM wheel nuts, if it's a conical surface then most aftermarket wheel nuts will do the job.
