Hi Guys,
Ive got an issue with my speedo, and I have tried many things to resolve it, but nothing has solved my problem.
1994 MR2 Turbo Mk2 Rev 3.
If the car has been sitting for a few hours
(i.e.
overnight or when I take it to work, 8 hours) the speedo works, although it does over-read pretty badly
(Actual 70mph
reading 85mph) and at low speed it under-reads slightly
(Actual 30mph
reading 25mph).
After driving for a while, the speedo needle begins to fluctuate a little and funnily enough the over-reading gets less.
A while longer and the speedo will stop working then jump back into life a few seconds later, normally this happens a couple of time until it stops working all together and the engine management light comes on.
From my observations it seems to worse in stop-start traffic, one day it work for 20 or so miles, but the main thing I thought of, was I hadnt had to stop at all, but on the way back from work that day in the stop start traffic, it failed after only 5 miles.
My big fear is that the cog on the diff is damaged and Ill have to pull the gearbox to fix it.
So what have I tried already, Ive replaced the speedo sender and speedo itself; Ive re-wired the speedo sender and run a new signal cable to the speedo itself, none of which has made a bit of difference.
Any advice will be gratefully received,
this is annoying me so much, I've considered just selling up.
Cheers for reading
Scott
