Fronts are solid and the rears are splits.
good stagger, gives a mean stance when fitted.
Fronts 16 x 7 ET 35
Rears 17 x 9 ET 22
One rear has a bit of curb damage.
Very light wheels.
Oh yeah, pcd is for mr2 114.3 I think.
CardHore wrote:So so cool..
I want those rears..
Agreed on aggressive stance on that offset.
Oooooossshhhh
The most important question is
Are the rears welded splits?
(Peel away at any sealant and see if there's welding apparent)
Let me know
CardHore wrote:Try the well where the tyre sits, thats what I meant dude.You should see a bead of sealant.
Pry some of it away and see if you can see any welding bead.
You cannot tell from inside the wheel
RedMR² wrote:How much posted for just the pair of 16 x 7 ET 35Enkeis?
Defo 5x114.3 Mr2 fitment? What's the center bore on the back of the wheel?
Thanks.
