Car sounds like a tractor after speedbump
robin91
Post by robin91 »
Hi everyone,
Basically I went over a speed bump yesterday and my car went bang lol. Next thing I know it sounds like a tractor on steroids.
I checked te flexi and it "seems" fine, still shiny and new looking. The bckbox also seems fine.
Only think I can see is a pipe leading from the manifold straight down blowing air, which has nothing on the end of it? It has a silver bell looking thing on top of the pipe ( sorry not tech minded ). But apparently when my friend covered his hand over this pipe, it sounded "normal" again. Is something meant to be on the end of this pipe?
Or any other thoughts?
Also went revving the car it seems sluggish
Thanks in advance
Hez
Re: Car sounds like a tractor after speedbump
Post by Hez »
I think your turbo fell off when you went over a speedbump! Must have been a big one.
robin91
Post by robin91 »
Yer the speed bump was the size of a mountain lol
I check the turbo and all connections. All seems fine.
Plus it hits boast ( sounds aweful! ).
Is this pipe in question meant to be open with nothing on the end? Or was a valve of some kind meant to be on it? Maybe something came off when scraping over the bump?
Hez
Post by Hez »
Sounds like a boost leak maybe, take a photo on a camera phone and post it, I'll tell you if it's right straight away.
robin91
Post by robin91 »
Hey Hez
My turbo is placed in an awkward place so unable to get a picture. Took it to a garage to ramp it up, they didn't have a clue as the owner modifed (customised) the engine.
The car is not pulling in boost like it should at 350bhp. Real luggish, anything to do with the exhuast system?
jimGTS
Post by jimGTS »
sure you havent cracked/split the downpipe??
mine once snapped in half! sounded like a tank.
Draven
Post by Draven »
jimGTS wrote:sure you havent cracked/split the downpipe??
+1 this check it see if there is a crack
jon_st205
Post by jon_st205 »
Sounds like you have an aftermarket setup with a 'dump' pipe or 'screamer' pipe depending on which you prefer. If the dump pipe is pumping exhaust off boost (like at idle) then I would suspect the external wastegate has either died or you've dislodged a vac pipe or two from it.
Cheers,
Jon
jon_st205
Post by jon_st205 »
btw the external wastegate is the 'bell' looking thing you describe :mrgreen:
If you aren't sure put up your location and a local owner will be able to help you for a few beers....
